Thank you to Kirk who helped me with a work around to display surface labels at a specific XYZ on FENCES even when those labeled locations do not have depth related data. I had to use a <<G>> glue character to finish the job.
In order to display surface labels at a specific XYZ on the Fence, we had to create "dummy" boreholes with XY and surface elevation (Z) data. I set the borehole depth equal to 0.001 ft. I created a blank record in Soil Description table with a depth of 0 and bottom of 0.001.
I then used an output condition for graphic columns and other Fence Entities that stated to only display boreholes with depths greater than 0.002 feet, so that only real boreholes and associated data would display depth related data and no dummy borehole depth-related data would display.
I then created a second text entity as the Surface Label to only display with a surface label criteria that I defined, but I also had to create a second graphic entity with the <<G>> Glue character so that I could have the dummy boreholes pass the gINT criterion stating that depth-related data are required for each borehole to be displayed on a FENCE, including the text entity Surface Label. The <<G>> glue character in essence tells gINT yes or "TRUE" there is depth-related data, but don't display this borehole data, just display the Surface Label text.
