Regarding the Standard gINT file "gint std a4 astm lab.lib", how can we make changes in the gINT rules? Please see the attached for reference. Thank You.
The field in grey AtterbergLimitsReadings is hard coded in the gINT Library and is not available for editing.
gINT Rules Code is available in the INPUT and DATA DESIGN>Library Data applications. Code is written and edited using the gINT Rules Codes menu option.
You can write code that will be executed on various events in these two applications.
Hi Aparna, Thank You.
