I'm unable to save the file after i finish designing the table. Please see the snapshot as attached for your reference.
Anyone familiar with this issue and has a solution?
Thanks in Advance.
Best Regards,
Sapna
Hi Sapna,
I have not seen this message, but the fact that it says the table cannot be locked because it is in use may require me to look at the current setup you have.
Please send me an e-mail with your contact information. I will call to see if we can troubleshoot. kirk.johnson@bentley.com
Hi Kirk,
Thank You for your response. Just forgot to mention earlier that we were trying to make changes to the standard files downloaded from Bentley's website. Is there any setting we need to change to fix that error?
Answer Verified By: Sapna Saini
No shouldn't be. The file should be in a location that the user would have full rights. If you have the file on the network you could test user rights and eliminate other users by placing it on your local C drive in a full rights location and try to edit it. Do you show all of the design tabs on your screen ? you should see Report design,data design, symbol design. If you don't goto file system properties , general and uncheck Hide design applications..If none of those work e-mail me and I can call to look at what you have setup
Just trying to clarify a few things here
1) It is on my local and i have full rights.2) I can't see the "Hide design applications" under general tab (using ver 8.1 ). But we can see all the design tabs.3) Strangely, i can edit and save the file now and not sure what has changed.
however, this takes me back to another issue we had - the examples files downloaded from bentley - we get this alert .
We can edit if we allow more than one user to open a file for editing, which ideally we don't want to. Any idea ?
Aslo, get this msg (snapshot below) after I click "check" (refer the above snapshot)
Please let me know if you have any questions.
Cheers,
