One of my logs spans two pages. The first page has the Logo in the left corner and my boring ID #/Page # in the right corner. Meanwhile the second page only has the logo showing up in output. How do I fix it so all three appear on the second page?
Hi Connor,
There are a number of ways this could be set up...
Often, these entities will be grouped together in a Block. In the Block properties (double-click on the Block Insert text), you can change the Page Range. The Block Insert also indicates the Page Range.
For more info about Blocks, see the Working With Blocks Wiki articles. Also, there are some good examples in our Report Design Tutorials here and here.
Another possibility is that there is an Output Condition to only show these entities on the first page. In the entity properties, check the Configuration tab and remove any Output Condition.
Answer Verified By: Connor Kirkland
I have checked both of these options. My page range is currently set to All and I do not have an output condition in place. When I created and edited my title block, I could have done it incorrectly. This might be why your solutions did not work for me?
Feel free to send me your library file (.glb) and project file (.gpj) and I can take a look. jesse.greenwald@bentley.com
Maybe the boring/page number text entities are assigned to a Private Block that is for Page 1 only? Check the Text Properties, Configuration Tab. If it is in a page 1 private block set to "none" and it should show on all pages
Thank you for the help, however, the private Block is already set to None.
