I just got a .glb file from client which causes these errors.
Could you please advise a method to repair them? The first happens when opening the .glb file, second one - when using import from excel file.
Thanks.
1. ActiveX component can't create object-2146827859
2. ActiveX Automation: server could not be found. 10095
You do not have Dataforensics Security Tool installed, to utilize these features it must be installed.
Hi Didis,
The message looks like the files have 3rd party addins (not from Bentley) and rules code tied to the addin. If you want to e-mail me your contact info I will contact you to look at it in more detail. kirk.johnson@bentley.com
