Overlay blocks
Is it possible to overlay log blocks ?
Sapna
  • Not sure what you exactly mean by an overlay of log blocks.  Do you mean multiple blocks to combine? Though there are quite a few major risks involved in doing so, you may want to take a look at the 'Consolidate Log Blocks property' which is under Blocks >Consolidate log blocks.  This command cannot be undone so the program makes a back up of your library file before starting it.
    You can read more about it in the Help section Consolidate Blocks (command)
