Hi
I've several input of the same geology unit 1 in the "Strata_Main". I'd like to reflect the geology unit in the output fences.
However, when I changed the depth expression to try to centralise the geology unit text, (have also checked the option to remove repeated text), the geology unit text is still not centralised in the output.
Would really appreciate any help!
Thank you
PDF
Hi Qinyi,
There is a Help topic in gINT that covers this including sample code. It is designed for gINT STD US LAB file set , but can apply to many other database structures. You would need to modify the code to match your database accordingly. Also you would use center Alignment when using this example.
In gINT goto Help.. Search
Using the help technique it would look like this.
Hi Kirk Johnson
That is really helpful! Thank you so much, will explore further on that!
