I am wanting to know if it is possible to do the following:
There are occasions where we will be working across multiple Project Numbers which may have different clients - but all the holes are on the same "Site" (therefore I want to keep the data together)
I'd like to have a Project Table that contains the Project Numbers, Client for Project Number.
I would then at Point Level like have fields for the Project Number and Client (so this can feed through into the logs) BUT I would like the Client (or additional fields should I add them in) be populated based on the selection of the Project Number.
Hi Paul
Make an ItemKey table (we will call it PROJECT_LIST). ItemKey being your project number, and add fields to this table for Client etc.
Add a field on your POINT table (we will call it ProjectID) that looks up PROJECT_LIST.
On reports use the <<Lookup()>> function to grab PROJECT_LIST fields based on POINT.ProjectID.
regards
Phil
Phil WadeDatgelBentley Channel Partner and Developer PartnerE: phil.wade@datgel.com | T: +61 2 8202 8600 & +65 6631 9780
Get the most out of gINT with Datgel Tools.
Thanks Phil - will give this a whirl.
