accidentally deleted a feature in the "report design" tab, gINT
I was wondering if anyone had any suggestions for a simple way to retrieve/re add a feature that had been accidentally deleted from a log template on the "report design" tab?
  • Hi Fraser,
    Reports in the report design tab are stored in the library file. The library file is a separate file. It has a .glb file extension. The best option would be to recover a backup or have your IT dept recover a backup (assuming it is store in a location that is backed up regularly). If you do not know the name and location of the library file you have open goto file ..system properties....library file . This will tell you the path and name of the library file you have open.
    For more information about the main file types used see .
    gINT has three file types (a file set): the gINT project (.gpj), the gINT lIbrary (.glb) and the gINT data template (.gdt). Each of these files plays a crucial role in gINT's functioning. The following…
