Database error, for seemingly no reason
Hello, over the last few times gINT has been used (either myself or my coworker) the program will suddenly stop working and act like the program becomes corrupt. I have attached a photo of one of the errors that show. There are 2 errors and all it will allow you to do is continuously hit 'ok' and then a runtime error will close the program after about 30 error messages are clicked through. In one project, the SAMPLE tab was randomly moved and most of the tabs which should have been under the Lab Testing tab were in the main group tabs as well. The sample tab did not have any of the populated fields it should have had such as the drop down for sample type.
I tried several things including restoring the library file to previous versions. It is NOT the library file, it appears to ONLY be the particular project file that crashes that has this issue. I was able to start a new project and copy and paste each individual log information into a new project file and that worked, but it is obviously time consuming to have to do so. This has now happened to 2 different projects over the past few days and it seems to happen randomly from what I can tell.
Any assistance would be greatly appreciated
