I am having problems with the termination notes of my logs. When the termination depth of the boring gets too close to the bottom of the page, the termination notes try to populate all in the small space available instead of getting carried over to the next page (see image below). I know that these termination notes can be found under the report design tab, then double clicking on "* description", followed by going to the Boundary Text tab, and finally in the space for Text Below Last Line. However, I do not know how to edit this. This is the code I have there right now:
<<ListBuildSepTrim(<<CR>>,<<DelimitData("Bottom of hole at ",<<POINT.HoleDepth>>," feet.")>>,<<POINT.Termination Notes>>)>>
I would greatly appreciate your help.
Thank you,
ERA
What software and version are you using so your question can be moved to the proper forum?
Tamicca SellarsMicroStation Product Manager
Answer Verified By: Eduardo Rodriguez Arriaga
It seems I did not do a good job about navigating this website. I apologize about posting in the wrong forum. I am using gINT v8i. Thank you Tamicca.
I created a new post on the correct forum. Thank you.
