Missing Design Application Tabs WITH system properties box unchecked (gINT Pro Plus)
I have had the same version of gINT Pro Plus running on a company laptop for some time. Oddly enough, my design application tabs have mysteriously vanished. I am aware of the System Properties > General > Hide Design Application check box, which is unchecked in my gINT settings. However, I still do not have access to the design application tabs. Has anyone experienced a similar issue?
Any help would be greatly appreciated.
  • Hi Thomas,
    If you just unchecked it close and reopen gINT.
    There are a couple of other ways design tabs could be hidden other than the system properties settings you mentioned.
    One would be if someone secured the library so that only certain users could edit or have read write access. Under the secure library settings there is an option to hide associated applications which can include the Design applications. If this is the case when you open the library it would be read only to you.
    As second reason might be the tabs are hidden because someone wrote gINT rules (VBA code) to hide them based on your user role etc...
    If you think that neither one of those have been done then contact me privately click on my name and send private message with your contact info and we can look at it in more detail.
