Change the print order of multiple entities at once while in the drawing function.
In gINT, is it possible to change the print order of multiple entities at once? I would rather not have to click on a hundred different entities and go to the configure tab a hundred times. I realize I should have foreseen this in the report design tab but I miscounted and would rather not recreate the entire cross section.
It would also be nice if I could just move around layers so all entities on layer A move behind layer B.
Best,
Sean
  • Hi Sean
    Modify > Copy Properties is the answer.  It allows you to copy the properties of an entity to many other entities of the same type, e.g. text. First set one entity as needed, then copy the settings to many other entities.  This can be used for layers too.
    regards
    Phil
    Phil Wade
    Datgel
    Bentley Channel Partner and Developer Partner
    E: phil.wade@datgel.com | T: +61 2 8202 8600 & +65 6631 9780
    Get the most out of gINT with Datgel Tools.
    Answer Verified By: Sean Parry
Reply
  • Hi Sean
    regards
    Phil
    Phil Wade
    Datgel
