I am making an internal block header trying to add the light non-aqueous phase liquid (LNAPL) level after drilling. I have tried to add "LNAPL" and "DNAPL" to my Water Level Event Library Data, but my associated text does not pull the data to the log. Is there a specific way I need to add the new listings other than Data Design > Library Data > Water Level Event?
Hi Joel,
You would also need to add the new events under User System data. I have attached a short video that describes how to do this. Hope this helps.
Answer Verified By: Joel Krech
