Producing a Compaction Curve Report Error
I am getting this error below, and it is only happening in producing a compaction curve report.
  • Hi Patricia,
    Typically this means there is not enough data to output to the report based on what is being called into report. Use the pick list to pick the borehole and tests or select borehole list to make sure you are getting the right borehole Id .
    If That doesn't work then send me the files privately to kirk.johnson@bentley.com and I will look at the data and the expressions
    Update: The data was missing from the Compaction readings table. This is what is graphed in the report to create the compaction curves. See below for example of data needing to be filled out.
    Answer Verified By: Patricia Arabit
