Hey,
I've started getting an error when trying to load the geology or monitoring tables (GEOL & MONG). I've not altered these tables in the Data Template and even in older projects these tables no longer load. I tried repairing and converting the projects but this didn't work either.
Has anyone else seen this before? Without remaking my my data template is there a way to fix this?!
Cheers!
Hi Brian,
Thanks for reporting it. As described by Microsoft, any "Update" query might result in this error.
Phil,
We are not planning to contact every user that might be affected by this Microsoft update. This patch might not affect every one since the pace of updating Microsoft patches is different for each organization.
Marie-Claude
Hey Marie-Claude,
I also had the error on Excel imports (direct and mapped), I didn't try any other import so unsure if the others are affected. I noticed the duplication of entities (although pretty sure I could delete them) in Report Design. I also found if a change had been made to a template the corrupt error also appeared in Output when previewing or attempting to export, if the template hadn't been changed the Output tab worked fine.
Cheers,
Ryan
Hi- just to keep things on record. I had the same problems but in a series-
1. I noticed when I exported databases to excel it would export blank excel document (unsure if this was related). However, my IT department solved this by asking me to export to my downloads folder- no idea why this worked. But this problem started before November I believe.
As of last week...
2. My library files would duplicate any changes I made and/or would not delete designs/ code. It continued to tell me my source file was missing (not exact wording).
3. YESTERDAY, all of my databases started to say the files were corrupt when I selected my water table information.
In conclusion, this update has effects in waves. It doesn’t all appear at once after you update. So odd!!
Faith
Greetings,
This issue was originally brought up in November 2019. It is now 5 months later and I still have to continuously remove the same security updates in order for my gINT to function as designed. Is Bentley going to find a fix to this issue at some point? Or have you assumed it is a problem that is going to resolve itself?
