Inserting axis labels in fence diagrams
I have manged to show results for dynamic probing on a fence report next to my borehole...… does anyone know how I create / insert a vertical and horizontal axis to show depth vs blows n/100mm?  can this be done on a fence report?  see picture below.
  • Hi Dominic,
    Yes you could add text entity to display the number scale with repeat values to represent the Increments and you can use Vertical scale Tick and Text entities for the Depth Scale. I believe you are Using the Standard AGS file set (library and Project). Below is a video showing how to use a column entity (Barchart vs depth) from a LOG report to set up the graph and then copy the exploded entities to your fence. I think this is the easiest especially since you are probably using AGS files. Although this technique could be used with any structure. Hope this Helps.
  • Hi Kirk,
    Thank you for this, much appreciated, will let you know how I get on!
Reply Children
