Report Design/Format Difference between gINT v.8.2 and v.10
I used to work on gINT v.8.2 and now I got a new gINT v.10. I tried using the same project file (.gpj.) and library file (.glb) in the new gINT v.10, but the report format (e.g. font, margin of text box) is distorted from what I used to got from gINT v.8.2. I double checked that the settings in report design between the two gINT are the same. Anyone have ideas about what's go wrong. Particularly for the text box, what kind of properties should I change so that the margin would fit? I want to keep the style as in gINT v.8.2. Many thanks.
 from gINT v.8.2
 from gINT v.10
