<?xml version="1.0" encoding="UTF-8" ?>
<?xml-stylesheet type="text/xsl" href="https://communities.bentley.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/"><channel><title>Exclude one / multiple legend patterns from a variable legend</title><link>https://communities.bentley.com/products/geotechnical1/f/geotechnical-forum/191789/exclude-one-multiple-legend-patterns-from-a-variable-legend</link><description>I&amp;#39;ve just created a variable legend sheet for a project. Is there a way of excluding one particular legend pattern from showing? There has been one added for END OF HOLE which is just showing as an empty box. I would like this excluded.
 Thanks in advance</description><dc:language>en-US</dc:language><generator>Telligent Community 12</generator><item><title>RE: Exclude one / multiple legend patterns from a variable legend</title><link>https://communities.bentley.com/thread/566609?ContentTypeID=1</link><pubDate>Thu, 30 Jan 2020 18:07:12 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:4666d309-62f8-479b-93cb-586ad4ced488</guid><dc:creator>Kirk Johnson</dc:creator><description>&lt;p&gt;Hi Paul,&lt;/p&gt;
&lt;p&gt;&lt;/p&gt;
&lt;p&gt;A variable legend entity will show what symbols are picked in Input from the field specified. If you just want to show a blank section in the graphic column ,my suggestion is to not use a graphic. Just enter a depth and bottom and leave the graphic column blank. Since you didn&amp;#39;t pick a graphic nothing will show in the legend, but you will still get a blank section on your report output.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
