I think I have opened a wrong library before. I can't open gINT now, I keep having this error message " Gint will now close automictically. You could select a different library by double clicking on one in File Explorer" I followed the instruction but without success! I also tried to open the library file from a backup copy. Please give some direction.
Hi Miranda,
If you are getting the message that gINT can't find a library and you must browse. Then when you browse to a library file, one with a .glb and it still says the same thing it may be a library with an old Access structure that may need to be converted. It depends on the version of gINT you are running. If you create a debug log per below it will give me the information about what version of gINT you have etc...
The best place to start might be a screen shot of message and a debug log, along with the library file you are trying to open.
All of these can be e-mailed to me and I can open a service request kirk.johnson@bentley.com
Here is how to run in debug . Please send me the text file per instructions below.
If you want to create a Service Request and attach the files to the request you can also create one and attach the files, instead of sending me the files.
