Hello all,
I am new to gINT, and have a bit of trouble getting my elevation markers to show up as I want them.
The photo on my left shows the overlapping issue that I have, and the photo on the right is what my log looked like earlier today. I'm not sure what I could have done to change this, and have found no way to fix it in the column - vertical scale properties pop up in the report design tab. I do not want to have to change any of the formatting on the scale, and would rather just have the 833m text disappear, as it was doing on its own earlier today.
Thanks for the help,
Nick
Hi Nick,
I would be difficult to troubleshoot the issue from just the pdf. It does look like the Elevation or formatting changed between the two, so it is possible that has something to do with it. Another property you might want to look at on your scale entity is the suppress positions. You could choose to suppress first to see if that works. I can't tell from the pdf if you have a column entity or individual scale entities.
Open the column entity in report design .. in the main tab choose suppress first.
If this doesn't give you the results you want then I would need to look at the files(library and project)
Here is some good general information on report design
