I want to add a new column, when I am in the Column-Text vs Depth Properties, In the Main - the existing column content were there, should I have to make a copy first then enter the new information? and how? if not will this overwrite the existing column content?
If you make a new Column- Text vs Depth, enter the properties and make a new one, gINT retains the properties entered. It will not overwrite the previous one. If you want to copy an existing Column-Text vs Depth entity, there is a copy command you can use. From there you can edit the properties.
I created the new column, the new column shown up in the Report Design, but not in the Main Group? I am not sure what did I missed.
I think I understand your question.
When you make a new column in Report Design - it does not make a new column where you enter data on the Main Group. To do that, you need to make a new field in the Data Design. After you have configured the new field within Data Design, you will see the new column in the Main Group. After that, you can reference the data with a column in the Report Design.
Hi Miranda,
There are some very good tutorials that would help you to do the things Allan has described. For example adding a new field in your database in Data Design is shown in the Data Design Tutorial.
Mapping that new field into a column entity in report design is covered in the Logs tutorial for report design
