Lithology/Stratigraphy description on log from multiple tables
In the Soil/Rock description area in my log, I need to combine information from three sources so that text gets appropriately stacked and pushed down and so that stratigraphy lines are drawn appropriately.
- I am pulling each sample soil description from the SAMPLE_DESC table through a Component Library Table named DESCRIPTION SOIL LITHOLOGY - I have tested it and it is working
- I am pulling each rock run description from the ROCK_RUNS_DESC table through a Component Library Table named DESCRIPTION ROCK LITHOLOGY - I have tested it and it is working
- The above are specific to each sample.  The lithology break lines are coming from the STRATIGRAPHY table which is not sample based, but just a PointID, Depth table.  These breaks may come after multiple samples, depending on how things are grouped.
I am trying to combine the above in a COLUMN-TEXT VS DEPTH PROPERTY entity on my log.  How do I combine these three items so that the three items don't overprint each other?  I've lost count of the different things I have tried to make this work.
Thank you for your assistance.
