Before I head on a path that leads me to a dead end, I'm wondering if I can do this a Gint graph. I did some searching in the Wiki and could not figure out how to do it.
I want to show a graph of groundwater elevations vs time for one or more instruments in a boring. I also want to show rain precipitation vs. time which will have a totally different Y-axis.
Can this be done? Any overall tips to get me started?
Thanks.
I could not get it to work. I was able to get a compaction curve overlay to work, but I was not able to get rain data (which is not based on POINT) to plot on the same graph using the overlay function with the piezometer data which is POINT based.
You need to use GDW export, not overlay, as the data has a different keyset, best done via a script, for example:
**Operation OUTPUT **Command EXPORT **Properties Type=Graph Name=MON HYDROGRAPH A4L Report_Variables=<ARRAY> Title,Groundwater Level versus Time Drawn, Drawn Date, Checked, Checked Date, Figure Number, Scale Text,Not to Scale </ARRAY> **Spec Project=datgel monitoring tool 3.00.gpj Range=DMT-Piezo SP-7 Trans x 1|3|T1,DMT-Piezo SP-7 Trans x 1|4.5|SP1,DMT-Piezo SP-8 Trans x 2|4|T1,DMT-Piezo SP-8 Trans x 2|4.5|SP1,DMT-Piezo SP-8 Trans x 3|4|T1,DMT-Piezo SP-8 Trans x 3|4.5|SP1 ExportFile=pie graph.gdw GraphIndependentDiv=12 GraphDependentDiv=10 SiteMapOnly=0 DbSourceMode=1 GDWPageName=A Command Script 11/10/2015 12:16:53 AM **Operation OUTPUT **Command EXPORT **Properties Type=Graph Name=MON PRECIPITATION BARPLOT MULT A4L **Spec Project=datgel monitoring tool 3.00.gpj Range=DMT-WS-2 ExportFile=pie graph.gdw GraphIndependentDiv=12 GraphDependentMin=0 GraphDependentMax=40 GraphDependentDiv=10 SiteMapOnly=0 DbSourceMode=1 GDWPageName=A **Operation GDWOUTPUT **Command EXPORT **Properties **Spec ExportFile=pie graph.pdf IndividualDatasets=0 PDFBookmarkPath=ROOT,Graph - MON PRECIPITATION BARPLOT MULT A4L PDFBookmarkRelation=1 Range=A Resolution=600 GDWFile=pie graph.gdw
Note these lines
GDWPageName=A
I have all this working in the Datgel Monitoring Tool gINT Add-In, after 2 years of trying I think buying something that works has some ROI.
Phil WadeDatgelBentley Channel Partner and Developer PartnerE: phil.wade@datgel.com | T: +61 2 8202 8600 & +65 6631 9780
Get the most out of gINT with Datgel Tools.
