Hello
I am trying to edit/open and AGS file in excel and I get this message:
"This action cannot be completeted becasue the other application is busy. Chosse "swich to" to activate the busy application and correct the problem"
The swich to... does not work.
Can you let me know what to do?
Olia
Hi Olia,
Thanks for asking about this. Can you try rebooting the PC and see if it helps?
Thanks Martyn
I am working from home and the connection is slow today. Could this be the reason?
Also I have recently upgraded my gint version to 10.01.00.11 and when I export old files to AGS I get errors that I didn’t have before.
Like:
Check of the DICT group 5 errors or warnings or informational messages
ERROR: Line 999 - Heading 'MOND_METH' in group 'MOND' is not defined in the DICT group.
ERROR: Line 999 - Heading 'MOND_LIM' in group 'MOND' is not defined in the DICT group.
ERROR: Line 999 - Heading 'MOND_ULIM' in group 'MOND' is not defined in the DICT group.
ERROR: Line 999 - Heading 'MOND_NAME' in group 'MOND' is not defined in the DICT group.
ERROR: Line 999 - Heading 'MOND_CRED' in group 'MOND' is not defined in the DICT group.
Is it the correspondence file that needs updating?
View online
You received this notification because you subscribed to the forum. To unsubscribe from only this thread, go here.
Flag this post as spam/abuse.
Regarding gINT working slow, yes could be your internet connection speed considering you are working from home.
You mentioned about exporting older gINT files to AGS. How old are these? What version were they made in? Are these gINT AGS projects created from gINT AGS data template?
