BitMap Symbol -Angle Expression
Hi there,
I'm trying to change the orientation for BitMap symbol using using Angle expression in one of my dwg library / template. I can see the results while I'm previewing the output , but it disappears when i print it to pdf.
Did anyone face this issue before or have any idea?
TIA
Sapna
  • Hi Sapna,
    Is the Bitmap symbol an image from a camera?
    If so see this post. It may help resolve an orientation property on the image itself.
    Hi Thanks to Jesse Greenwald documenting this. Is this what you are experiencing? We found this thread about Windows 10 (and also newer Windows 8) auto-rotation behavior, which sounds very similar…
    If it is a bitmap that was designed in an image editing program like paint or inkscape, is there an alternative vector symbol you could try? For example Discrete Graphic symbols and DataMarker symbols are vector in gINT.
    It might be easier to assess if I had the files and context of what you are trying to create. Feel free to send me the gINT files privately so I can take a look at the details.
    kirk.Johnson@bentley.com
