I am currently deleting surfaces in my gINT project. Surfaces are stored in a separate file, but this file doesn't reduce in size while I'm cleaning it... Has anybody got this already?
It is a bit annoying as I have to keep handling huge files with little data in it. It seems that the surfaces are removed from the surface list but the data is still kept. Is there a way to fix that?
Hi Jerome,
If you are talking about the file size of the gINT project file (.gpj) then try repair and compacting it. goto utilities ..Repair Compact.
Answer Verified By: jerome garnon
Hi Kirk
no I'm talking about the Surface file .gsf.
But your solution might still work, I'll have a go and let you know.
Thank you.
Jerome
Yes it worked with the .gsf file as well! Thank you.
