GintPointSort using sigle digit number and sorts in wrong order
we are using GintPointSort rule (GR016) for sorting boreholes with different names. Assigning sort number works properly. Problem is that gint rule assign number with single digit (without leading zero) which causes problem with sorting (1,10,11,12,13,2,3,etc.). How can I change the sorting rule to insert also leading zero for single digit number so the sorting works properly?
Thanks for any advice.
With regards
Jakub
