My horizontal distances on a fence diagram are incorrect, I'm new to the program and trying to learn.
Are you talking about the X scale of the data frame?
Phil WadeDatgelBentley Channel Partner and Developer PartnerE: phil.wade@datgel.com | T: +61 2 8202 8600 & +65 6631 9780
Get the most out of gINT with Datgel Tools.
The horizontal distance will be based on the units of the coordinates for North and East. Check that those are in the units you are expecting, such as meters vs. feet
Hi Tom,
As others have mentioned the distance is units entered in the program. The x axis is the distance along the base line. If you have not provided a baseline or an alignment then the program draws a best fit line as the baseline. The distance on the x axis is then shown as the distance along this line.
If you have your own baseline you can put it in the output screen.
Here may be some useful material in understanding fences and how they work both from the design standpoint and some of the output options
If you need more detailed help, please click on my name and send me a message. We can set up a Service Request and go into it in more detail with your files.
