I am sure i am just not looking in the right places however I am trying to plot design lines from a table with 'depth top', 'depth bottom', 'Su top', 'Su Bottom', like so:
Depth top
Depth bottom
Su top
Su Bottom
0
10
2
22
Can anybody direct me on how to do this please?
Chris
Hi Chris,
I am not sure I am envisioning exactly what you are trying to make.
On a Log report design there are line entities you can use. Vertical line to depth allows you to draw a vertical line and you have a top depth and bottom depth expression. There is also a lines versus depth entity where you can draw a line at depth and set the width this would draw a Horizontal line.
The most common way would be to include the lines in the column entity for example the boundary line tab in a text vs depth column allows you to define a horizontal line at the top an bottom of the range and will draw a line the width of the column.
Likewise the range line property in a column entity will draw a vertical line in that column from top to bottom of range defined in the main tab of the entity.
There is a lot of material in gINT Help.
For the individual line entities
Search "Vertical Line to Depth"
Search "Lines Vs Depth"
For the column entity properties
Search "Boundary Lines"
Search " Range Lines"
Here is the report design tutorial which is a great resource.
If you need something more specific. Click on my name and send me a private message and we can look at your files and discuss what you want the final output to look like and I can give more specific instructions.
