Hello
I am new to gINT logs and trying to learn how to modify the report design to my liking.
I changed so many thing in report header and column header that I cannot bring them back
I uninstalled the application and reinstalled it again but all the changes in Report Design are still the same
Is there anyway I can reset the setting so it goes back to the default setting?
Hi Haybert,
The changes made to the gINT library are not reversible. Therefore we always recommend to make a backup of the original library before making any changes/edits to your library including report designs.
You have a few options:
1) If you are saving your gINT library on your network drive, ask your IT to see if you can get a back up of the library before you made these changes.
2) If you were using gINT standard library as your original library, then you can download the standard gINT files and uses the original library.
You can download the standard gINT files from here. These files are in a zip format that contain a library file, project file and a data template. Extract the files in this zip to your C:\Users\Public\Documents\Bentley\gINT folder. If you are using the latest version of gINT then the folder will be C:\Users\Public\Documents\Bentley\gINTCL. If you do not have a library folder listed under gINT or gINTCL, then go ahead and create a new folder called 'library' and put the gINT library file from the zip to this location.
