Hi, everyone! When I add GRID LINES in Report the GRAPHIC COLUMS disappear. If I remove them, the graphic columns appear again. Can someone help me, please?
Many thanks in advance.
Nilton
Hi Nilton,
Turning on and off grid lines in the fence report properties should not have any relation to the graphic column entities. Would you mind sending me the gINT files (library and project ) so I can look at it in more detail. Please also include the version of gINT you are using. goto Help ..about gINT to find the version number.
kirk.Johnson@bentley.com
Thank you, Kirk! I'll do that!
