gINT software opening
hello
I have a problem with opening the gINT software (to create logs), an error message opens every time i try :
Someone can help me?
thank you in advance for your help
Chloé CARDOT
Golder associates
ccardot@golder.com
  • Hello Chloe,
    This error mostly suggests an issue with permissions for using gINT.
    User needs to full control/permissions on the following gINT folders:
    • C:\Users\Public\PublicDocuments\Bentley\gINT or C:\Users\Public\PublicDocuments\Bentley\gINTCL (gINT or gINTCL will be based on which version of gINT you have),
    • C:\Users\<user_login_name>\AppData\Local\Bentley\gINT or C:\Users\<user_login_name>\AppData\Local\Bentley\gINTCL
    • C:\Program Files (x86)\Bentley\gINT or C:\Program Files (x86)\Bentley\gINTCL
    Make sure gINT has been installed as an administrator.
    Check this post that talks about the similar error:
    Hi! I have some troubles after installing gINT on the new computer. If I double-click it on the Desktop icon, it writes down: Startup Main Error location: 21 Number: 91 Description: Object variable…
  • Hi Chloe, you are offline now, but I am creating a ticket for you with our Help Desk.  Melanie
  • Hi, I just saw your issue was resolved, so I am not going to create a new ticket.
