I have a graph report for index tests. I'd like to go to output and print the results for all borings, but I want the page numbers at the upper right of the graph report to only have the number of pages for each boring. Right now when I print for all results, it prints, for example, page 1 of 57, but I want it to be 1 of 3, when there are only three pages of results for a boring, and then start again at 1 for the next boring.
My page number code is: Sheet <<Pg>> of <<Npgs>>
This code works fine for boring logs in that I can select all logs to print, and it restarts at 1 for each log. It doesn't seem to work the same way for graph reports. Is there a different code I should use?
Thank you.
Hi Monique,
I'm not aware of a different code that will do that for graphs. Maybe I'm missing it though, and someone can correct me.
The tedious workaround would be to output the graphs 1 boring at a time. However, that could be automated with a gINT Rule that runs a separate Output script for each boring. Our SIG recording from June 2019 describes how to implement something like that.
