Filter on Graphs
I have a graph to display Particle size curves, whose Key Set is set to "PointID,Depth".
It works very well until I try to apply a filter on the POINT table at output time (on LOCA_CLST for example). Then I always get a "... return no data" message. I also tried to filter within the report (<<IIf()>> statement)...
Is it because the filter should only apply to the "GRAT" table (I noticed it appeared by default in the filter dialog)?
In that case, would there be a better way than adding a new field in GRAT (or GRAG) automatically filled by lookup to the POINT table field...?
Thank you
Jerome
Parents Reply Children
