In the column 'Moisture' no data output, I found the error from REFERENCE TO CURRENT FIELD '0 references found to <<MOISTURE.MOISTURE>>.
How to reference it?
Hi Miranda,
The screen you are showing is a field property that sees if that field is referenced in any of the reports in the current library you have open. It could be that you have another library file that has reports that reference that field. In that case goto file ..change library and open a different library file.
If you want that information to show up on a report you will need to write an expression to call it into a column. There are a wide variety of ways that can be done and a wide variety of entities, report types that this is done.
Below is the report design tutorial that describes how to create a column and write expressions (call in tables and fields into reports)
If you need more specific information based on your custom database and reports please create a service request online and add your custom gINT files (library and Project) to the service ticket.
https://apps.bentley.com/srmanager/ProductSupport
