I would like to create a well diagram that has an uneven vertical line to represent a borehole wall in rock (for an open borehole well). It seems that only solid vertical lines are possible in the well diagram by specifying a right or left border in Symbol/Tile. Are there any workarounds to do this?
thanks
Hi Gavin,
There are so many possibilities with symbols and well diagrams it's hard to say without seeing what you want it to look like and how you are going to use it. But if you want to create something really simple and use an existing tile do something like this. Use tile Misc 47 to create a well symbol and use the percentages that match your other pipe symbols. Leave the vertical borders blank. If you want to create fill symbols on each side you can do that also.
If this doesn't work send me an e-mail with an image of what you want it to look like along with your current files library and project and I'll reach out and you can design something much more detailed that would work with your custom file set. My e-mail is kirk.johnson@bentley.com
Answer Verified By: Gavin Kitchens
