I am having a reoccurring issue with not being able to open gINT. I am running version 10.02.00.04 on a Windows 10 Pro machine (version 1909) and am getting the loop error that has been reported in the past:
gINT cannot locate a gINT library
Please browse to your library file
If you do not select a library gINT must exit
Attempts to select a library results in the message popping up again.
I have uninstalled gINT and the 32-bit Access Database, reinstalled gINT from the Bentley website and let gINT reinstall the Access Database, then restart the computer. This does work, but only temporarily. I have turned off Windows updates in attempt to stall Windows from changing the Access Database with updates. However, it seems that every time I come back to try and open gINT (a few days to a week or two later), I'm right back to square one and have to do this whole process over again.
What is the permanent fix that can be implemented so that this issue can be resolved and it is no longer necessary to uninstall and reinstall every time I would like to use this program?
Hi Marylou,
This issue is happening due to Microsoft Office 365 updates. These office updates are breaking the 32 bit Access database 2010 engine which is required for all gINT files to read and operate. We have filed a ticket for this issue with Microsoft, but unfortunately will get reset with Office updates until this is fixed.
Instead of reinstalling the Access database engine each time, you can try to repair the access database engine.
Here are the steps you try mentioned in this post:
Hello Aparna,
Thank you for the quick reply. Your help is greatly appreciated. I will try the repair process and test over time too see if it helps.
Hi Aparna,
Just wanted to check to see if there's any movement or additional details on this issue? Or a creative/stable solution for the interim?
Over the last few months I've used a 'semi-permanent' workaround on certain client PCs of replacing the MSO365 version w/ a standalone earlier version of MSO and a standalone earlier version of MS Access runtime to run our in-house database w/ success but this is not available on our client PCs which require MSO365.
The simplest temporary solution I've found seems to be an in-place re-install of the database engine w/ the version packaged w/ our version of gINT (roughly as simple as the repair solution which seemed to break the Access runtime depending on version).
Daniel
Hi Daniel,
We have filed a ticket with Microsoft on this Access Database issue. Until a permanent fix is worked out, unfortunately repair or reinstall of 2010 Access Database 32 is the way to go around.
Thank you for the response Aparna. We'll keep doing what we've been doing.
