I am trying to create a soil boring log that contains both soil and rock information. For some reason, my soil sample data is showing up on the PDF, but none of my rock core details (Sample graphic, sample number, recovery %, RQD) are being transferred to the PDF.
I have filled those sections out in the Rock Core tab. Below is a screenshot of what I'm talking about. gINT doesn't seem to be recognizing the data. When I try exporting as a Rock Core Log, the data is successfully transferred to the PDF.
If anybody has an idea, please let me know.
Thank you,
Scott
Hi Scott,
This depends on how your custom gINT files are setup Library .glb and project .gpj. The Soil log may not have any of the expressions in the report mapped to the rock data tables because it was not originally intended to display that information. If you have a separate rock report and the data shows then it contains all of the correct expressions in the report design entities to call in data from those tables.
The quickest way to help you and to give you accurate information based on your custom files is to have you send them to me (library and project) to kirk.johnson@bentley.com with your contact information and I can call and discuss the best options for you based on your files.
If you want to edit yourself Below are some tutorials that may be helpful.
I would highly recommend making a copy of the report and edit the copy so the original is still intact .
To do so goto report design pick the report in the yellow drop down . Then goto File...copy page ..give the new report a name. hit OK and then edit the copy.
If you want additional information about report design and writing expressions here is a detailed tutorial.
Hi Kirk,
Thank you for the help. Luckily, we had a previous library that we borrowed the rock core "code" from and transferred it to the soil boring design. It worked as a quick fix. Thanks again for your response!
