Wrapping notes text
Hello, I am a new gINT user (especially when it comes to report design). I have tried searching through the forums for an answer to this question but have not found anything that satisfies the requirements that I have.
I am trying to wrap my Notes header. You can see in the screenshot below how it extends off the page. I imagine that the remaining text will take up two more lines underneath Notes. This is part of a Blocks header that I have modified a little bit. I'd appreciate any help or knowledge that you can pass on to me!
  • Hi William ,
    There are quite a few ways to do this , but the main issue is that entity has an associated text property . This combines the label the text from input and the line all in one entity but you can't set wrap width. I have created a short video of an example of one way to do this. Keep in mind there are many ways you can do this. Hope this helps.
    Answer Verified By: William Dunn
Reply
  • Hi William ,
