Adding surfaces in fences
I am a new user of gINT Professional. I tried adding surfaces to 2D fences. I have added the .grd files, but while exporting the pdf output, its displaying a message "Surface 'Bedrock' not output. Extent falls outside the output region. Surface 'Ground surface' not output. Extent falls outside the output region."
Also the new graphics created are shown on preview, but not while exporting. Please do help me resolve the above issues.
Thanks in advance,
Sruthy Nath
Geocon International Pvt Ltd
  • Hi Jaydeep,
    There shouldn't be any difference between the preview and export to pdf (assuming all of the exact parameters were the same when previewing as pdf). The message is standard if the surface falls outside of the vertical extent , based on your baseline, but would be the same in preview. It should give you the message and then output with the surface showing because if falls outside the extent. The easiest way to troubleshoot is for me to take a look at the files. Please send me the library , project , and it would also be nice to have the .grd file and any other output specs you have assigned (baseline or alignment, scale you have set on the horizontal Axis.
    You can send them to kirk.johnson@bentley.com
    Also make sure you are using the latest version of gINT . 10.02.00.04
    Here are download instructions.
    gINT and HoleBASE Product Support Following the gINT and HoleBASE product support announcement in January 2023 a Frequently Asked Questions document has been created to provide further details and outline…
