i have gint file and i want to convert into ags4 format, new to thing, please explain the process to do it
Hello Shahid,
gINT comes with a gINT data structure (.gdt) that mimics the AGS structure and contains all of the groups and variables defined in the AGS specification. Correspondence files have been created to export data from this database to the AGS specification and to import data directly from AGS format data files. The following pre-made files you will quickly move you into production.
.GLB – Library that contains lookup lists, symbology, reports, etc.
.GDT –Data template that describes the gINT database structure
.GCI – Import correspondence files
.GCX - Export correspondence files
In the latest version of gINT 10.02.00.04, go to gINT>Help>Manuals, you will find gint_and_AGS3.pdf and gint_and_AGS4.pdf
Also, under gINT>Help>Contents>AGS Support will provide all detailed chapter by chapter description.
You can download AGS Datasets from here
