How do i put a range for my dip on rock discontinuities? For example 60-70, my library currently only allows for one value e.g. 70?
Hi Siya,
If your Dip column allows only one value, then mostly the data entry for this column is restricted to numeric integer and will not allow at character like a - between the numbers. You will have to change the type field to either memo or text to except the anything but a numeric value.
To change that go to Data Design - File - Open File - Current Database - Navigate to your Discontinuity table from the top yellow drop down list - identify the Dip field in the list and change the type.
Answer Verified By: Siya Nyathi
