gINT for ArcGIS toolbar
I'm still trying to install gINT for ArcGIS Toolbar.  My IT department says it was installed with gINT but I don't see it anywhere.
Where do I look for this?  How do I activate it?
I've seen the configuration file mentioned elsewhere but can't find it either.
Please help.
Robert..
  • Hi Robert,
    Go to the Help menu in gINT and select the "Manuals" option/command. This will bring up a Windows dialog with a listing of all the gINT manuals that have been installed on your computer. There you should find the "ArcGIS_toolbar_manual.pdf file. In the PDF you will find information how to install the toolbar (as you indicated it should already have been installed), configure the toolbar, and how to use the toolbar.
    Note that the toolbar is accessed from ArcMap, not from within gINT.
    Unfortunately, I don't have ArcMap installed on my computer so I cannot provide more details than what is included in the PDF file.
    Hope this helps.
    Dave Kyllonen
