I'm fairly new to gINT - I need to know how to add a 'Depth Log Page' to an existing file that does not have one for some reason. Second I need to know how to link that field so that the units of measurement and total depth are reflected in the output file or existing template file.
Thanks Kirk! This was what I needed. But alas, the library file is protected. I don't have a default US library. Do you know if that should have been part of my download when I got it installed on my work computer? I remember when I went to open it for the first time I couldn't run the program because I needed to select a library and I had to go hunt one down from someone in our office. I am now thinking that shouldn't have been the case. Do you happen to know if the install should have included a set of standard libraries and templates?
In addition to what you have, I've put a note at the bottom of my logs to reflect the "Project Wide" scale. Meaning, there's a text expression at the bottom which says something like 1"=<<PROJECT.BORELOGSCALE>>' so that I can double check with a scale.
