Can I just rename the library file? will this cause any issue in referencing the project file?
Hi Miranda,
If it is just a library name, then yes you can rename it. It wont cause any conflict with the project file.
When you want to use the library make sure to use the correct one since it will reference the templates, graphics, user system data expressions and much more.
Hi Miranda,Just to expand on Aparna's answer.Your project doesn't link in any way to a library. So yes you can rename your library.
BUT - as Aparna saidYour project is dependent on you using the right one otherwise things wont work like
Aparna M said:templates, graphics, user system data expressions and much more.
Software plugins too are usually installed into your Library as well as your PC.
