Materials Design Display settings
Does anyone know how to fix the offset in the Material Design section? The dashed line does not extend across the length of the section and the depth is overlapping the graphic log section. I have tried to manually move the section in Report Design tab, but have had no luck. How do I fix this and what should the offset setting be?
Parents Reply Children
