When I open gINT I get the following errors in the order listed below.
Run-time error '0'
Error in Startup.StartProgram (429)ActiveX component can't create object Line number 21
Run-time error '429':ActiveX component can't create object
Then it just closes.
How can I fix this?
Hi Joel.
Do you have a multiple screen display? If so certain HD monitors can cause an issue where gINT is sizing the monitor. Try to open gINT on your main monitor and change the display setting accordingly.
No I just have one monitor but it is a 49" ultrawide. I searched the forums and I see that a lot of people have had this issue without any satisfactory solutions.
I was able to resolve it with the following steps
My gINT is having this same issue. Tried the above steps (thanks for sharing!) and was unsuccessful. However, I'm not using a monitor - just my laptop.
Emma, are you having an exact same error in the same sequence? Was gINT working for you before?
My error says "Class not registered". Yes it was working when I last used it last week.
