Morning All,
Ive generated a borehole model from gINT Civil Tools and included my properties to be attached from the gINT database. For some reason Ive ended up with multiple versions of each. Why would this be?After deleting the objects and re-querying with only GEOL_DESC included, the other empty holders are still there. Is there a way to get rid of the empty property holders that i didn't specify for output without starting the file from scratch? Using GCT Connect Update 7.Thanks
Rob
Hi Rob,
I can reproduce it I'll report it to development , this looks like it needs to be fixed. The only workaround I can think of is to hide those options . There may be something better, but if you right click on (where it says geology on yours) there is a show hide option . Just show the ones you want this seems to change all of them.
