I would like to know how to change the language of a log report. For example I want to use the "GENERAL BH/TP/WELL" log report, but by default GINT has it in english (see pdf below).
I would like to edit the words and create a template in spanish. Anyone knows how to do this?
Thanks.
PDF
Hello Pelelo,
If you just want to rename the column header and change the names to Spanish, you will need to open each of the column by clicking the X in the middle of each column. A column property dialogue box will appear. Navigate to the Column tab and change the name header. This will change the name of the column to your desired name. Save this.
In gINT the report templates will be based on the library you are currently connected to. If you want to connect to different datasets based on countries, you can download them here:
If you want to change the language of the project tables, and the columns only, you can go to Help>Language and select from the list. This will change the Input headers to the selected language.
Thanks Aparna.
I checked the Spanish database and clearly it doesn't have the same log report style as the US Gint version.
Please refer to the file attached. Is it possible to merge or combine both portions of each database or library into one?. I would like to combine the ones the areas that are in blue in each page.
Or do you have any other suggestions how to proceed with this?
Please let me know. Thanks
Pelelo,
Please send me a private email with your contact details at aparna.matange@bentley.com so that we can discuss this further.
The merge is not going to be so straightforward as it appears. The spanish Header from the spanish library looks at the spanish project dataset whic has the the project database laid out with spanish table names, with spanish column headers. Whereas the regular US datasets are all with English project table and columns which get called upon in the report.
gINT requires correct association between table, column into report design. With a mixture of languages that possibility will extremely complicated and will be something that will need large amount of customization on your part.
